jhun3xx
nEx
- 672
- 472
- 563
Autodesk 3DS MAX 2022 (x64)
Description
Autodesk 3DS Max software delivers efficient new tools, accelerated performance, and streamlined workflows to help increase overall productivity for artists and designers working with the complex, high-resolution assets required by today?s demanding entertainment and design visualization projects.With the ability to import, visualize, and render massive point cloud datasets; enhanced viewport performance; and new scene management workflows, 3ds Max helps artists and designers handle greater complexity without slowing down.
In addition, a more responsive ActiveShade interactive rendering workflow that now supports the NVIDIA mental ray renderer, and a new artist-friendly node-based visual shader editor for creating and previewing complex real-time shaders help increase efficiency for lighting, shading, and rendering tasks. Meanwhile, with new support for Python scripting, 3DS Max offers a robust core toolset that is more easily extended and customizable to meet each studio?s unique requirements.
Features:
Create, shape, and define a range of environments and detailed characters
3ds Max works with most major renderers?including Arnold,V-Ray, Iray, and mental ray?to help create striking scenes and visuals
Build imaginative characters and realistic scenes in games and architecture
Revit, Inventor, and Fusion 360, as well as SketchUp, Unity, and Unreal, all work with 3ds Max
Build immersive architectural visualizations with the combined power of 3ds Max and a virtual reality engine
Create, share, and update portable assets that are flexible, connected, and react to changes in design data
Match your UI to the way you think and work with a more responsive, modern, and customizable user experience.
What's new:
Security
Smart Extrude
Slice Modifier
Extrude Modifier
Symmetry Modifier
AutoSmooth
Relax Modifier
Rendering
Arnold
Bake to Texture
Viewports
USD in 3ds Max (Public Beta)
System Requirements :
[ Minimum Req. ]
Supported OS: Windows 7/8/8.1/10
CPU : 64-bit Intel or AMD multi-core processor with SSE4.2 instruction set
Memory (RAM): 4 GB of RAM (8 GB recommended)
Hard Disk Space: 6 GB of free disk space for install
DOWNLOAD:
https://drive.google.com/file/d/1wB9V7I-6UZkK-pISxVHX5gChUxsH2Hhs/view?usp=sharing
RAR Password:
jhun3xx.symbianize
