COLORFUL Introduces GeForce RTX 4070 Series Graphics Card Lineup
– Colorful Technology Company Limited, a professional manufacturer of graphics cards, motherboards, all-in-one gaming and multimedia solutions, and high-performance storage, introduces its lineup NVIDIA GeForce RTX 4070 graphics cards. Available in a Vulcan, Neptune, Advanced, Ultra White, and Battle-Ax models, the COLORFUL GeForce RTX 4070 Series delivers next-generation performance powered by the Ada Lovelace architecture.
The GeForce RTX 4070 GPU includes all the advancements of the NVIDIA® Ada Lovelace architecture, including the new standards in gaming such as DLSS 3 neural rendering and real-time ray-tracing technologies. Starting at $599, the GeForce RTX 4070 runs most modern games at over 100 frames per second at 1440p resolution.
iGame GeForce RTX 4070 Vulcan OC
The COLORFUL iGame GeForce RTX 4070 Vulcan OC adapts the new design shared with other RTX 40 Vulcan Series that features the improved Hurricane Scythe Blade fans, the iGame Smart LCD, and the Hallow Back Panel that provides a flow-through airflow design. The Vulcan model sports discrete RGB lighting accents that are fully customizable using the iGame Center app.
A highlight feature of the Vulcan Series, the iGame Smart LCD is detachable and can be placed on the graphics card or on a dock which users can place anywhere on their desk or gaming PC. The iGame Smart LCD can be used to display images and GIF images. It can also be used for real-time monitoring for enthusiasts that are keen on what going on with their gaming PC. The iGame Smart LCD can be flipped 90° to make the display visible even when the graphics card is installed vertically. A Vulcan Lightboard is also included that replaced the iGame Smart LCD on the graphics card when the display is installed on the dock.
- One-Key Overclock: A conveniently placed button located at the rear I/O that activates overclocking function for a quick and easy performance boost without opening software.
- Hurricane Scythe Blades: Three 100mm Hurricane Scythe Blade fans delivering fan heat dissipation with its improved airflow compared to the previous-generation fan blade design. iGame Smart LCD: A removable magnetic display that can be mounted on the graphics card or on the included display dock. The display has a resolution of 800x216px – fully customizable via the iGame Center app to display real-time monitoring figures, custom images, GIFs, and others.
- Display Dock: The display dock is an external docking accessory that users can place on their desk or on top of the chassis that holds the iGame Smart LCD. The display dock connects the display via a USB cable.
- Vulcan Support Frame: The Vulcan Support Frame enhances the stability and structural rigidity of the entire graphics card. This eliminates the risk of bending and warping as it supports the weight of the card.
- Hollow Back Panel: A hollow back panel design that allows airflow to freely pass-through the heatsink. This design greatly improves heat dissipation compared to conventional GPU air cooling designs.
- iGame Accessories: The Vulcan Series comes with a set of accessories including the Screen Wipes, White Gloves, and Screwdriver.
Model: | iGame GeForce RTX 4070 Vulcan OC-V |
CUDA Cores: | 5888 |
Game Clock: | 2475MHz |
Boost Clock: | 2625MHz |
Memory: | 12GB |
Memory Type: | GDDR6X |
Memory Bandwidth | 504 GB/s |
Power Connector | 1x 16-pin PCIe |
Card Dimension | 348.5mm x 159.5mm x 60.5mm |
Display Output | 3x DisplayPort, 1x HDMI |
COLORFUL iGame GeForce RTX 4070 Neptune OC
The iGame GeForce RTX 4070 Neptune OC features an all-in-one liquid cooling solution with a 240mm radiator – delivering excellent heat dissipation. The Neptune’s superior cooling solution allows it to have a higher factory overclock, up to 2640MHz boost clock. This two-slot graphics card uses an aesthetic metal shroud with a matte silver finish and two RGB light strips that provides ambient lighting. The RGB light strips are fully customizable using the iGame Center app.
- Slim 2-Slot Form Factor: Slim 2-slot PCI thickness that will fit in most PC builds.
- Liquid Cooled: Harness the superior cooling performance of liquid cooling for higher overclocks at lower noise levels.
- Full-Cover Copper Waterblock: High-performance full-cover copper waterblock that covers the GPU, memory, and other critical components in the graphics card.
Model: | iGame GeForce RTX 4070 Neptune OC-V |
Boost Clock: | 2640MHz |
Memory: | 12GB |
Dimension | Card: 253.5mm x 170.8mm x 41.5mm Radiator: 227mm x 155.6mm x 54.4mm Pipe: 420mm |
COLORFUL iGame GeForce RTX 4070 Advanced OC
The iGame GeForce RTX 4070 Advanced OC sports the new Gravity Rim central fan design and the new Hurricane Scythe Blade design. It also features the Hollow Back Design with an iGame grille for aesthetics. The Gravity Rim has RGB lighting, customizable using the iGame Center app. The Advanced model also features the Hollow Back Panel design.
- Gravity Rim: A redesigned version of the iGame Energy Core that creates a mysterious black hole effect.
- Meteorite Backplate: A sturdy metal backplate that reduces PCB flexing. An intricate iGame grille design is added to the backplate’s hollow back to add aesthetics.
- Hurricane Scythe Blades: New fan blade design that delivers superior airflow compared to the previous-generation Storm Chaser fan design. The Advanced OC uses two 100mm fans and a 96mm center fan.
- Customizable RGB Lighting: COLORFUL is all about adding a touch of colors to your gaming PC. The graphics card features RGB lighting that is fully customizable using the iGame Center software.
Model: | iGame GeForce RTX 4070 Advanced OC-V |
Boost Clock: | 2610MHz |
Memory: | 12GB |
Card Dimension | 343.5mm x 150.2mm x 53.5mm |
COLORFUL iGame GeForce RTX 4070 Ultra W
The iGame GeForce RTX 4070 Ultra W sports a new look and design. Its holographic shroud displays different colors in different angles, complemented with RGB lighting and RGB illuminated “ULTRA” design on the side. It uses a triple-fan cooler design and is the thinnest air-cooled model in the series at 51.2mm thickness.
- ULTRA Retro RGB: Eye-catching and visualizing with the combination of the holographic shroud design and RGB lighting.
- ULTRA Cooling: A triple-fan cooler design with four 6-diameter copper heat pipes fitted with three 90mm cooling fans.
- Customizable RGB Lighting: RGB lit ULTRA design fully customizable using the iGame Center software.
Model: | iGame GeForce RTX 4070 Ultra W OC-V |
Boost Clock: | 2505MHz |
Memory: | 12GB |
Power Connector | 1x 8-pin PCIe |
Card Dimension | 324.9mm x 134mm x 51.2mm |
COLORFUL GeForce RTX 4070 NB EX
The COLORFUL GeForce RTX 4070 NB EX sports an eye-catching black and red design. The Battle-Ax model uses a triple-fan cooling solution featuring an enlarged heatsink with two 6mm copper heat pipes, equipped three 90mm fans. The Battle-Ax model sports an RGB lit COLORFUL branding on the side, customizable using the iGame Center app.
- Battle Ax Backplate: Improved backplate design that provides structural rigidity and passive heat dissipation.
- RGB Lighting: An RGB illuminated COLORFUL branding on the side that’s customizable using the iGame Center app.
Model: | COLORFUL GeForce RTX 4070 NB EX-V |
Base Clock: | 1920MHz |
Boost Clock: | 2475MHz |
Memory: | 12GB |
Card Dimension | 325mm x 134mm x 53.8mm |
iGame Center App
Download the latest version of the iGame Center app at http://colorful.cn/iGame-Center/
Availability
The COLORFUL GeForce RTX 4070 Series graphics cards will be available on the COLORFUL official stores this April 2023. See the manufacturer’s suggested retail prices below.
COLORFUL iGame GeForce RTX 4070 Neptune OC-V: $829.00
COLORFUL iGame GeForce RTX 4070 Vulcan OC-V: $819.00
COLORFUL iGame GeForce RTX 4070 Advanced OC-V: $709.00
COLORFUL iGame GeForce RTX 4070 Ultra W OC-V: $659.00
COLORFUL GeForce RTX 4070 NB EX-V: $599.00
Follow COLORFUL in the following social media channels below:
Facebook: https://www.facebook.com/ColorfulGlobal/
Instagram: https://www.instagram.com/colorfultechnology/
YouTube: https://www.youtube.com/channel/UCFCrgPOCH14pVVMMH2Nw-bA
TikTok: https://www.tiktok.com/@colorfultechnology
About Colorful
Colorful Group (CFG), is a manufacturer of motherboards, graphics cards, all-in-one PC, memory & SSD, industrial server, computer case, power supply, Hi-Fi player, industrial integration solution and services with over 24 years of experience delivering quality products garnering a brilliant reputation amongst its customers. CFG is an internationally renowned brands garnering recognition and awards. For more information, visit https://en.colorful.cn/
