COLORFUL Introduces iGame Z790D5 FLOW and iGame Z790D5 ULTRA Motherboards for 14th Gen Intel Core CPUs
The iGame Z790D5 FLOW motherboard features a wave-shaped cooling armor and aesthetic styling that is inspired by the “flow” of waves. On the other hand, the iGame Z790D5 ULTRA is a new model that’s designed to complement the ULTRA Series graphics cards. Both motherboards are equipped with an 18+1+1 power phase (90A Dr.MOS) design and DDR5 memory support. The DDR5 memory slots uses 30μm gold-plated contacts to achieve higher memory overclocks with greater stability, reaching up to 8200MT/s (OC).
COLORFUL iGame Z790D5 FLOW
The COLORFUL iGame Z790D5 FLOW motherboard takes inspiration from the calm flow of water in a futuristic design with RGB lighting on the VRM heatsink and chipset heatsink zones. The motherboard features an 18+1+1 Power Phase (Dr MOS 90A) along with an eight-layer PCB, Aerospace-Grade Tantalum Capacitors, and 30μm Gold-plated Contacts. The iGame Z790D5 FLOW is engineered to bring out the best overclocking performance out of the latest 14th Gen Intel Core i9 processors.
For storage, the iGame Z790D5 FLOW comes with four PCIe 4.0 M.2 slots complete with a high-performance heatsink along with six SATA ports. The motherboard also comes with a plethora of USB ports including a high-speed USB 3.2 Gen2x2 Type-C 20Gbps port that supports 30W fast charging.
- Supports 14th, 13th, and 12th Generation Intel Core Processors
- 18+1+1 Power Phase Design (Dr MOS 90A)
- 30μm Gold-plated Contacts on DIMM slots and PCIe slots
- Alloy-reinforced DDR5 slots
- Supports DDR5 memory, up to 192GB capacity and up to 8200MT/s (OC)
- Aerospace-Grade Tantalum Capacitors
- Four high-speed PCIe 4.0 M.2 slots
- Six SATA ports
- USB 3.2 Gen 2x2 Type-C 20Gbps (supports PD3.0 @30W)
- 2.5 GbE + WiFi 6E
- Supports RGB Lighting synchronization via iGame Center App
- Debug LCD for easy troubleshooting
CPU | Intel® 14th / 13th /12th Generation Core™ Processors |
Chipset | Intel Z790 |
Power supply phase | 18+1+1 Power Phase (Dr MOS 90A) |
Memory | 4x DDR5 DIMM Socket Dual-Channel*, Support XMP *Single memory supports up to 48GB capacity, total memory capacity supports up to 192GB DDR5-7800(OC)/7600(OC)/7400(OC)/7200(OC)/7000(OC)/6800(OC)/6600(OC)/ 6400(OC)/6200(OC)/6000(OC)/5800(OC)/5600(OC)/5400(OC)/5200(OC)/ 5000(OC)/4800MHz Memory Support |
Expansion Slot | 1x PCIe 5.0 x16 1x PCIe x16 (support PCIe 4.0 x4) 1x PCIe 4.0 x4 1x PCIe 3.0 x1 |
Storage | Support 6x SATA 6Gb/s Support 4x PCIe 4.0 x4 M.2 SSD* *3xM.2 SSD not support SATA M.2 |
Internal Connectors | 1x 24-pin ATX Power connector 2x 8-pin CPU Power connector 1x Front USB 3.2 Gen 2x2 Type-C (PD3.0 @30W) 2x Front USB 3.2 Gen 1 Type-A 4x Front USB 2.0 |
I/O Ports | 4x USB2.0; 2x USB 3.2 Gen 1 Type-A; 3x USB 3.2 Gen 2 Type-A; 1x USB 3.2 Gen 2x2 Type-C 1x HDMI port; 1x DP port; |
LAN | Realtek 2.5G + Wi-Fi 6E, Support Bluetooth 5.3 |
Audio | 7.1-Channel High-Definition audio CODEC |
Dimensions | 305mm*244mm, ATX |
COLORFUL iGame Z790D5 ULTRA Motherboard
The COLORFUL iGame Z790D5 ULTRA motherboard is designed to complement the ULTRA Series graphics cards with its pop-art style and holographic designs. The iGame Z790D5 ULTRA sports RGB lighting on its chipset heatsink and supports RGB lighting synchronization with supported devices using the iGame Center app.
- Four high-speed PCIe 4.0 m.2 slots
- Six SATA ports
- 2.5 GbE + WiFi 6E
Pricing and Availability
The COLORFUL iGame Z790D5 FLOW and COLORFUL iGame Z790D5 ULTRA motherboards are coming to partner resellers this Q4 2023. For more information on pricing, please contact your local COLORFUL Technology representative.
