COLORFUL Launches iGame GeForce RTX 50 MINI OC Series Graphics Cards for Compact PCs
GemsGemsGems
Colorful Technology Company Limited, a leading brand in gaming PC components, gaming laptops, and HiFi audio products, announces the global launch of the highly-anticipated iGame GeForce RTX 50 MINI OC Series graphics cards. Designed for compact PCs and small-form-factor PCs, the iGame GeForce RTX 50 MINI OC graphics cards measure only 180mm in length. The series makes its debut with the iGame GeForce RTX 5060 Ti MINI OC 8GB, delivering powerful next-generation performance in a refined, space-saving design – the iGame RTX 5060 Ti MINI OC 16GB and iGame RTX 5070 MINI OC 12GB will be launched at a later date.
The new COLORFUL iGame GeForce RTX 50 MINI OC Series represents a major visual and structural upgrade over the previous generation. The new MINI cards adopt a sophisticated matte black finish with a unibody metal shroud, elevating both durability and premium appeal. Subtle, star-like detailing across the surface adds visual depth, while the clean lines and well-balanced proportions reinforce the series’ mini but mighty philosophy— true “performance pocket rockets” engineered for compact systems without compromise.
Compact Design with Advanced Cooling
Despite its single-fan configuration, the iGame GeForce RTX 50 MINI OC Series features a robust cage-style metal cooling structure combined with extended heatsink fins and a 95mm seven-blade fan. This advanced thermal design ensures efficient heat transfer and strong cooling performance even within a compact footprint. Thanks to this enhanced cooling capability, the MINI series is also able to support higher-performance models, including the GeForce RTX 5070, reinforcing its reputation as a true performance-focused compact graphics card lineup.
Refined Industrial Aesthetics
The upgraded metal backplate adopts a clean industrial design, replacing previous accent colors with a matte black coating that resists fingerprints and enhances long-term durability. Signature iGame design elements are subtly integrated into the backplate, highlighting the card’s technological identity and performance heritage.
Adding a touch of personalization, the side of the card features illuminated “MINI” ARGB lettering, customizable through iGame Center software, allowing users to tailor lighting effects to match their system theme.
Built for ITX Enthusiasts
With dimensions of 180 × 123 × 39.8mm (excluding bracket), the iGame GeForce RTX 50 MINI OC Series is compatible with most ITX cases on the market, making it an ideal choice for compact gaming systems where space efficiency and performance are equally critical.
ModeliGame GeForce RTX 5060 Ti Mini OC 8GB-V
Boost Clocks2632MHz
Power Phases6+2
Heatpipes4x Φ6mm
Outputs3DP+HDMI
Connector8-pin PCIe
Dimensions180×123×39.8mm
Pricing and Availability
For more information on availability and pricing, please contact your local COLORFUL Technology representative.
Shiriru
