COLORFUL Launches iGame Guard G114 140W GaN Multi-Port Charger
cybermediapr
Gems
Colorful Technology Company Limited, a leading brand in gaming PC components, gaming laptops, and HiFi audio products, has officially launched its first GaN charging product, the iGame Guard G114 140W GaN Multi-Port Charger. Designed as a powerful desktop charging hub for modern multi-device users, the iGame Guard combines up to 140W of multi-port power delivery with a futuristic starship design and an intelligent iGame Display interface. The iGame Guard G114 is designed to provide a dependable power solution for desktop setups, gaming environments, and business travel. Supporting USB-C-powered laptops, tablets, phones, and other devices, it brings multiple charging needs into a single compact unit, helping users carry less without compromising charging capability.
Featuring a refined micro-textured surface, intelligent power monitoring, advanced GaN technology, and a 3C1A port configuration, the iGame Guard G114 140W brings high-performance charging into a compact form factor. With support for PD 3.1 EPR and multiple mainstream fast-charging protocols, it is designed to deliver high-power charging while providing clear, real-time information about power delivery, temperature, and usage.
Refined Surface, Built for Everyday Use
The iGame Guard features an scratch-resistant matte finish that resists fingerprints, scratches, and yellowing. Its compact 61 x 72 x 33.2mm form factor make it suitable for both desktop setups and travel.
iGame Display Provides Real-Time Power Information
The integrated iGame Display shows total output power, individual port power, cumulative usage time, and temperature status. Users can see power distribution and operating conditions at a glance.
140W GaN Power in a Compact Design
The iGame Guard combines PFC, AHB, and high-frequency GaN technology to deliver up to 140W of output in an approximately 145cm³ chassis. The architecture improves power conversion efficiency while reducing switching losses and heat generation.
3C1A Configuration with PD 3.1 EPR
The charger features three USB-C ports and one USB-A port. The C1 and C2 ports each support up to 140W (28V/5A) with PD 3.1 EPR, while C3 and USB-A provide up to 30W each. Multi-port configurations include 100W + 30W, 65W + 45W + 18W, and 100W + 7.5W + 7.5W.
Wide-Range Input and Extensive Compatibility
The iGame Guard supports 100–240V input and has undergone full-load testing at 90V and 264V. Its dynamic power allocation system maintains stable output when devices are connected, disconnected, or change their power demand.
Compatibility testing with more than 200 devices covers major charging protocols, including PD 3.1, PPS, QC, SCP, FCP, and AFC.
Designed for Stable Wall-Mounted Use
The iGame Guard's center of gravity, cable orientation, and load distribution are optimized to reduce outward tilting, sagging, and loosening when connected directly to a vertical wall outlet.
ModeliGame Guard G114 140W
Output powerUp to 140W
Interface3C1A (three USB-C, one USB-A)
Power supply topologyPFC + AHB
Weight252g±
Size61x72x33.2mm ±0.5mm
DisplaySupports display of total/individual power, usage duration, and temperature range.
Input voltage100-240V
C1/C2 Output powerUp to 140W (28V/5A)
C3 Output powerUp to 30W
USB-A Output powerUp to 30W
Muti-Output power100W+30W/65W+45W+18W/100W+7.5W+7.5W
AlimuddinKhan
