- 5,578
- 4,929
- 3,396
GiliSoft File Lock Pro is a power file encryption software program that can quickly and safely lock and hide files, folder,and drives,and it can use 256-bit AES encryption (Encryption Standard Adopted by the US Government) to protect your files located on HDD drive or any portable media such as USB drives.
Features and Benefits
- GiliSoft File Lock Pro can hide your private files folders and drives, to make them completely invisible to users and programs.
- The locked files/folders/drives are protected from accessing, users can not open, read, modify, move, delete, copy, rename the protected files/folders without password. Files and sub-folders in a locked folder are also protected.
- It can encrypt files and folders of any type.
- It packs and encrypts a folder into an executable (.exe file) with AES encryption algorithm. You can encrypt important data by this method, and then send it over the network or by other means to be used on a machine without Gili File Lock Pro.
- GiliSoft File Lock Pro allows you to completely remove sensitive data from your hard drive by overwriting it several times with carefully selected patterns.No one can recover deleted data from your disk if you secure delete it.
- GiliSoft File Lock Pro is a password-locked software,that is to say,there's no other way to run or unstall it if you have not the password.
- Fully support Intel® Pentium D Dual-Core Processor and AMD Athlon™ 64X2 Dual-CoreProcessor;
To see this hidden content, you must reply or react with one of the following reactions : Like, Love, Wow
