jhun3xx
nEx
- 672
- 472
- 563
Hard Disk Sentinel (Repack & Portable) is a popular program for monitoring and controlling the health of hard drives. Allows you to identify potential problems, performance degradation and possible failures. In case of detecting any malfunctions or excess temperature, the application will immediately notify the user about this. The program monitors the status of hard drives, including temperature readings and SMART parameters. In addition, it measures the data transfer rate in real mode.
It can work in the background and constantly monitor the situation with disks.
Supports work with drives via IDE, Serial ATA and SCSI interfaces. It detects the status and temperature in real mode, while the readings are displayed instantly. Displays the current and minimum temperature of the drives, the total running hours and the number of read / write errors.
Defines drive models and displays detailed information about them. Can display the highest possible and current data transfer mode.
In addition, there are a large number of additional options for customization for personal needs (management of alerts, logging of collected data, synchronization of system time, automatic shutdown, etc.)
Features Repack Hard Disk Sentinel:
1. Combined installation of the program or unpacking of the portable * version in one distribution kit
2. Does not require registration (patch MPT / fix addhaloka /)
3. Multilingual interface (including Russian)
4. It is possible to install / unpack the program with a modified icon
5. Picks up the external HDSentinel.ini settings file (if located next to the installer)
* Unpacking the portable version is possible in two versions: from the developer and portable app format
System requirements: Windows 7/8 / 8.1 / 10
DOWNLOAD
http://gestyy.com/epR7Ds
RAR Password
jhun3xx.technoypi
RAR Password
jhun3xx.technoypi
