IObit Driver Booster 9 PRO (v9.0.1.104) Multilingual
kzen773
Gems
Driver Booster is a must-to-have utility designed to update all outdated drivers on Windows. As we all know, those obsolete drivers may adversely affect the PC performance and even cause system crashes. Developed by IObit, Driver Booster provides the best one-click solution to rapidly and securely update outdated drivers, install missing drivers, and fix incorrect drivers. Apart from updating drivers, Driver Booster also introduces several powerful tools to increase the system compatibility and stability.
What makes Driver Booster so attractive?
Fully Supported Windows 11
As soon as Microsoft introduces Windows 11 to the world, IObit makes Driver Booster fully support Windows11.
Very Large Driver Database (8, 000,000+)
While providing millions of driver updates, Driver Booster ensures all the drivers provided are from official websites or Windows and have passed WHQL and strict IObit Review Rules. These certified drivers can be updated without worries about system or security problems.
Automatically Scan and Update
You can create a scheduler to scan at a fixed frequency or at each Windows startup. Meanwhile, it saves you plenty of effort and time by checking the checkbox ?Automatically update drivers while the system is idle?. It totally frees you from checking the status of drivers and driver updates one by one.
Powerful Tools
No sound, bad resolution, and no internet connection are probably the headache for all PC users. With IObit cutting-edge technology, Driver Booster employs its foolproof Tools: Fix No Sound, Fix Network Failure, Fix Bad Resolution, Fix Device Error, etc. These tools must be one of the greatest achievements of Driver Booster. It becomes a child?s play to fix those general PC handicaps.
Mighty Backup & Restore
No one can guarantee there would be never a problem if you update the driver. To minimize the bad effect of any unexpected troubles caused by driver updates, Driver Booster provides mighty strategies, including backing up the drivers, creating a system restore point. With these, you can reverse the update or restore the system to fix the troubles.
Offline Driver Updater
What if a computer has no internet connection? Driver Booster can also help you fix the problem caused by drivers. Offline Driver Updater is employed for those computers without internet connection, especially for newly installed Windows computers.
Ultimate Gaming Experience
Apart from fixing general problems caused by drivers, Driver Booster can also bring gaming experience to a higher level. It not only provides necessary game drivers, but also offers Game Boost which can optimize PC performance for better gaming.
In summary, Driver Boost is supposed to be the first choice when you need a driver update tool no matter whether it is used to improve PC performance or get better gaming experience.
IObit Driver Booster 9 Update History V9.0:
+ Fully supports Windows 11
+ Greatly expanded database by 78% to support updating 8,000,000+ drivers
+ Enhanced multiple tools (Clean Invalid Device Data, Fix Device Error, Fix No Sound, etc.) for better system stability
+ Strengthened Backup & Restore to support backing up multiple versions of drivers
+ Improved Game Boost to support enabling Game Mode in Windows Settings directly
+ Brand-new UI for more concise interface, easier operation, and smoother experience
+ Supported 37 languages
+ More can be discovered by you
System Requirements
- Windows XP/Vista/7/8/8.1/10
- 1 GB of free disk space mainly for driver download and installation
- 1024*768 screen resolution and above
Install Notes:
- Install App
- Exit The App from System Tray
- Copy Content from Crack Folder to Install Directory
Download Link:
https://mega.nz/file/WIhjWIaA#QqyamxXOwi0qtwZwFcjYAKrct8BEOgrrQ5lk3ytsfbA
