IObit Smart Defrag PRO v7.2.0
kzen773
Gems
In the course of time, the access times on conventional hard drives slow down noticeably. Often this is due to the many individual file fragments that accumulate over time, as related files are never saved in one piece, but are found scattered across the hard drive. The more often you create, delete, copy or move files, the more the performance deteriorates. With Smart Defrag from IObit you counter this problem. The multithreading defragmentation of the tool rearranges the file fragments neatly one behind the other in order to offer faster data access and better hard disk performance. Instructions: Click on the button below this text. The setup file will then start to download. Install the program on the computer and start it. The license code for activating the full version can be found as a graphic above the button. Enter this code to unlock the program.
This is the 6-month license, for noncommercial use
Download Link:
https://mega.nz/file/CFgygZ7S#fTuczE0VYm66_e4DD6XkFQlvc5rHvJWCun_EKoziALc
License Code:
https://anotepad.com/notes/j6je9xiy
Rob1234
