IObit Uninstaller 11.1.0.18 (Repack & Portable)
jhun3xx
nEx
IObit Uninstaller Pro ( Repack & Portable) is an uninstaller for Windows designed to completely remove unnecessary (for one reason or another) programs and applications (and not only) installed in the operating system.
The application is in many ways superior to the standard Windows tool, and unlike the latter, it does not leave any "tails" of previously installed programs that have been removed, which more than favorably affects the performance and "health" of the operating system as a whole.
The main features of the program:
- There are several ways to uninstall programs: regular and batch. The batch method is necessary when you need to uninstall several programs at once.
- Support for the forced uninstallation module, which allows you to remove those programs that cannot be removed in the usual way and clean their "traces" in the file system. Also, this module will be able to delete any file or folder, including the system one (for example, the Windows folder - but it is better not to do this, since after that the operating system will not boot).
- Removing plugins and toolbars from internet browsers.
- Reset all settings for a specific browser.
-File shredder support for "permanent" deletion of files and folders. This tool is necessary for those who want to permanently delete personal files from a computer (for example, a database with bank accounts) so that no program can restore them.
-Support for a log containing the history of deleted programs (name, time, method used and list of deleted files).
-Create and view restore points.
Features Repack IObit Uninstaller Pro:
  1. Combined installation of the program or unpacking of the portable (portable app format) version in one distribution kit
  2. Does not require registration (patch)
  3. Removed ads, adware modules and other "garbage" inherent in IObit programs
  4. Optional installation of IObit Uninstaller Service
  5. Optional integration of the program into the Explorer context menu
  6. Optional integration into Windows Control Panel
  7. Multilingual interface (including Russian)
  8. Picks up the custom settings file Main.ini (if located next to the installer)
System requirements:  Windows 7/8 / 8.1 / 10
DOWNLOAD
http://gestyy.com/epR8za
RAR Password
jhun3xx.technoypi
