[PC APP] ISO Workshop 11.4 Pro incl Patches
baitmaster
Description:
This program will allow you to work with disk images. I think many of you know that optical disc images can store any data and they can be created from CDs, DVDs and Blu-ray discs. Often, images are used to completely copy all data from optical discs, and it is also easier to distribute images on the Internet, since you do not have to get up from the couch and go to the store to buy the original disc, you can download ISO Workshop in full news from our website.
Images have a huge number of advantages, the main one is that they copy the original disk sector by sector and completely preserve its structure, and after using the image, your drive will rest and wear out less, and of course you won’t have to pay for the original disk itself, so how you can find a huge number of images on the net, for example, toys. If you want to recreate the original disc with an image, the tool will help you burn the image to a blank CD, DVD and Blu-ray media, it will be decompressed and you will end up with the original optical disc.
So, the main features of the program: having an image on your computer, you can extract the information you need from it and save it to a specified location on your hard drive, the application allows you to copy a disk to ISO or BIN image format if you have an image of an unknown format that needs to be converted in ISO - the program will help you here, the last is the ability to burn a disk image to any type of media.
Of the advantages, a very simple and convenient interface with support for the Russian language can be noted.
Small installation file size
When working with the program, the system resources of the computer will almost not be consumed.
The program is free for both home and commercial use, supports almost the entire Windows family and any type of drive.
I have nothing more to add, we have considered all the advantages, the choice is yours, whether you need a simple utility for working with disk images or not.
License: ShareWare
Language: English
How to Install:
1). Instructions are included in ReadMe.txt if needed.
2). That is all, Done & enjoy.
To see this hidden content, you must reply or react with one of the following reactions : Like Like, Love Love, Wow Wow
Password : technoypi.com
