- Jun 5, 2023
- 75
- 141
- 175
Nut Pr0 T00L v1.0.4 + Added K3yg3n
==>>>is a new t00L for Android Qualcomm and Mediatek devices. It helps users to solve many problems that they face while using their smartphones. The tool has a paid version, but I have made it free for everyone by byp4ssing the login.Features Nut Pr0 T00L:
=>UNL0CK MTK
![Check mark button :white_check_mark: ✅](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/2705.png)
=>MTK Meta
=>UNL0CK QUALCOMM
=>UNL0CK ADB
=>UNL0CK FASTBOOT
To see this hidden content, you must react with one of the following reactions :
Love,
Wow
- First, you need to download the zip file from the below link
- Next, you can unzip all files at c: drive (important)
- Ensure you have disabled the antivirus before running the installation
- Extract all files on the desktop, open the folder, and follow the next steps
- Run the "NUT_PRO.exe"
- Before running the tool you can please move the folder "windDB" to the "C:\Users\pcname\AppData\Roaming"
- Next, you can install all drivers if you already installed skip this step
- Connect the phone and try to do any function
- That's It! Enjoy And God Bless You..
#share
#PCApps
#badkingph
![1699255628375.jpg 1699255628375.jpg](https://technoypi.com/data/attachments/2/2472-916a1a01a438773675aae0f4a7b39f90.jpg)
