Orpalis PDF Reducer Pro 3.1.21 (Repack & Portable)
jhun3xx
nEx
Orpalis PDF Reducer Pro (Repack & Portable) - is designed to compress PDF documents before publishing them on a website, sending them to storage or sending them by e-mail. The application interface is simple and clear. All the user needs to do is select the source document, specify a folder to save the optimized version and click on the "Start" button. All other actions will be performed without your participation. In some tests, the document size remained virtually unchanged, but in some cases, the compression level can reach an impressive 80 percent.
The product is based on fairly simple technologies. The program achieves the desired result by manipulating the DPI (dots per inch) characteristic and recompressing the document with a slight deterioration in image quality. During processing, the program also gets rid of some not very important document elements, such as form fields, annotations, bookmarks, embedded files. However, if this approach seems unacceptable to you, you can manually configure the cleaning options in the "Settings" dialog box. Special mention deserves the ability to process a large number of files in batch mode. You can download the program via a direct link (from the cloud) at the bottom of the page.
The main features of the program:
  • Content segmentation to increase compression ratio
  • Automatically applies the most efficient compression schemes based on data type
  • Serialization of multiple compression algorithms
  • Uses an innovative automatic color recognition engine
  • Page layout analysis
  • Removing unused objects
  • Removing unwanted specific objects such as annotations, bookmarks, form fields, attachments
Orpalis PDF Reducer Pro repack  features :
  1. Combined installation of the program or unpacking of the portable (portable app format) version in one distribution kit
  2. Does not require registration (pawel97 patch)
  3. The language of the program interface is English, French, Russian (translated by AlexYar)
  4. Picks up an external settings file settings. data (if located next to the installer)
System requirements:  Windows 7/8/8.1/10
DOWNLOAD
https://drive.google.com/file/d/1Np2ObA8FdQU2F5gYmJU3zV0I10WwyiCV/view?usp=sharing
RAR PASSWORD
jhun3xx.technoypi​
