[PC APP] Photodex ProShow Producer 9.0.3782 + Effects Pack 7.0 + Pre-Crack
baitmaster
Software version: 9.0.3782
Language: Russian + English
Platform: x86 / x64
Developer: photodex.com
Medicine: All cured
Author of assembly: KpoJIuK
System requirements: NET Framework 3.5
Description: ProShow Producer- A new version of the application for creating professional presentations, which includes hundreds of new features and an updated interface. The program supports working with layers and allows you to use an unlimited number of layers for each slide. The program supports transparency for PSD, PNG, TIFF and GIF files, makes it possible to use layer masks, transition effects, gradient fill or fill color. Photos used in the presentation can be edited by applying to them tools such as sharpening, changing the contrast and color saturation. The presentation can contain signatures, including animated, and background music. The finished project can be saved in one of fourteen formats, including HD Video, Flash and QuickTime.
Additional Information
Sets of styles and effects included in the distribution
ProShow Style Pack 1
ProShow Style Pack 2
ProShow Style Pack 3
ProShow Style Pack 4
ProShow Style Pack 5
ProShow Style Pack 6
ProShow Style Pack 7
ProShow Effects Pack Portraits
ProShow Effects Pack Sports & Action
ProShow Style Pack Escapes
ProShow Style Pack Grunge Appeal
ProShow Style Pack Vintage
ProShow Style Pack Weddings
ProShow Transition Pack 1
ProShow Transition Pack 2
Version Features
Type: installation, unpacking portable [Punsh]
Languages: Russian, english
Activation: MPT
Command line options:
Silent installation of the Russian version: / S / IR
Quiet installation of the English version: / S / IE
Unpacking the Russian portable version: / S / PR
Unpacking English Portable version: / S / PE
Do not create shortcuts on the desktop: / ND
Do not create shortcuts in the Start menu: / NS
Select the installation location: / D = PATH
The parameter / D = PATH should be specified the latest
For example: Photodex.ProShow.Producer. v9.0.3776.exe / S / IR / D = C: \ MyProgram
Note! Restart the computer if some words are displayed by krakozyabrami.
Note!!! When installed, on the first page of the installer, you will be prompted to change the browser home page. Do not forget to remove the check mark.
Important
Before installing a new version, make sure to back up the installed styles and transitions.
The official installer can sometimes remove them.
Restart the computer if some words are displayed by the krakozyabrami in the installation version.
For a portable version of the change, you must manually make a change from the "Correction folder" folder.
In the program paths there should be no Cyrillic alphabets, unwanted spaces and spets. characters.
To see this hidden content, you must reply or react with one of the following reactions : Like Like, Love Love, Wow Wow
Boss, bakit ganon, walang link na lumabas po nung pinindot ko yung click here? hehe. sorry, late reply. haha.
