Process Lasso 10.3.1.10 (Repack & Portable)
jhun3xx
nEx
Process Lasso (Repack & Portable) - helps to solve the problem when Windows, by default, allows programs to completely load the central processor, which leads to system freezing and, accordingly, to inconvenience.
The utility neatly realigns the priorities of running programs, so that processes that previously loaded the entire CPU will no longer affect the response of the system.
The main features of the program:
? Dynamic balancing of the priority of processes to optimize performance
? Using standard process priorities
? Acceleration in the foreground
? Limiting the number of running copies of programs
? Prohibiting the launch of specific programs
? Keeping statistics of running processes
? Dynamic graph of system load
? Separate core engine program
? Support for 32-bit and 64-bit systems
Graphical Interface Features:
? Easy installation rules of priorities and process affinity to the default CPU
? If desired, the display of tooltips to notify you at the time of actions
? A unique system for calculating the reactivity of the system and displaying a graph
Features of the Process Lasso repack  :
  1. Combined installation of the program or unpacking of a portable (portable app format) version in one distribution kit
  2. Does not require registration (patch RadiXX11)
  3. Multilingual interface (including Russian)
  4. Picks up external settings files settings.reg and prolasso.ini (if located next to the installer)
ATTENTION!!! Possibly FALSE operation of antiviruses on the portable loader (ProcessLassoPortable.exe file)
System requirements:
  Windows 7/8 / 8.1 / 10
DOWNLOAD
http://gestyy.com/epR8XY
RAR Password
jhun3xx.technoypi
