- 5,578
- 4,929
- 3,396
Professional DJ software - From the unknown to the greatest, Serato DJ Pro is the most popular DJ software globally. When you're talking about Hip-Hop, Dance, and everything in between, you're looking at the standard.
Rock solid reliability
Serato DJ Pro is renowned for its reliability and trusted by DJs to deliver incredible performances. That's why it powers the world's top artists on some of the biggest stages.
The best hardware
Serato DJ Pro officially supports over 90 pieces of hardware by industry leaders. Every piece is tightly integrated to ensure the best experience possible.
Limitless performance
Whatever your style, you can DJ with freedom. Your creative potential will be unlocked through innovative features and an intuitive interface.
Numark Mixtrack Platinum FX support
The Numark Mixtrack Platinum FX is a 4-deck controller that has 6’’ capacitive-touch jog wheels with onboard track information display. It comes with 16 Performance Pads along with six dedicated Serato FX controls for you to use in your sets. Onboard controls allow you to browse and load tracks along with creating and adjusting loops.
Numark Mixtrack Pro FX support
The Numark Mixtrack Pro FX is a 2-channel controller that has 6’’ capacitive-touch jog wheels. It comes with 16 Performance Pads along with six dedicated Serato FX controls for you to use in your sets. Onboard controls allow you to browse and load tracks along with creating and adjusting loops.
Denon DJ X1850 PRIME support
The X1850 PRIME is a 4-channel mixer from Denon DJ. It comes with extensive connectivity allowing you to connect up to four media players or turntables, along with dual USB ports for multiple laptop connectivity.
Serato DJ Pro 2.3.6 is out now, bringing support for the Hercules DJControl Inpulse 500.
Hercules DJControl Inpulse 500 support
The Hercules DJControl Inpulse 500 is a compact 2-channel controller. It comes loaded with everything you need to perform, with unique features including its retractable feet to elevate the controller.
- Practice Mode
- New UI with Performance Pad view
- Optimised for high resolution screens
- Bigger Libraries and rock-solid reliability
- Improved help and support
Release Notes:
New Features:
- Support for the Pioneer DJ DDJ-FLX4.
Bug Fixes:
- Fixed an issue on Windows for the Denon DJ SC Live 2/4 where changing the buffer size in the driver panel doesn’t update Serato DJ buffer slider and start a new audio connection.
- Fixed an issue in some cases after Phase is disconnected the WIR deck option is still visible on screen.
System Requirements:
- Operating System: Windows 10 (64-bit)
- Processor: i3: 1.07GHz, i5: 1.07GHz, i7: 1.07GHz, i9: 1.07GHz
- Screen Resolution: 1280 x 720
- Memory: 4 GB
- Free HDD Space: 5 GB
Homepage: https://serato.com
Run predone setup, install & Enjoy, No activation required / Instruction is Included in the folder!
To see this hidden content, you must reply or react with one of the following reactions : Like, Love, Wow
