[PC APP] Shield Antivirus Pro v5.0.5 + Crack
baitmaster
Shield antivirus offers protection from all to-date viruses, malware, ransomware, trojans, and spyware for personal desktop and laptop computers. Shield antivirus utilizes active protection mechanisms to protect your computer from all threats and is set to monitor, block, and alert whenever a threat is detected.
Shield Antivirus features an easy installation process, vast monitoring and alerts capabilities, as well as email protection by blocking and quarantining any threats located in incoming emails. Shield antivirus offers full protection from internet/browsing threats at a fraction of the CPU load due to its advanced detection engine and algorithms. Shield antivirus will automatically scan a computer for threats on a defined schedule and also includes extra tools and features such as the secure file eraser, history cleaner, and start-up manager to help keep your computer protected and operating at peak performance.
Shield Antivirus Highlights:
Active Protection
Shield Antivirus provides a completely hands-free PC protection and is set to monitor, block and alert whenever a threat is detected.
Deep Threat Scanner
Shield Antivirus finds & eliminates threats that are hidden deep in none-standard sub-folders and hard drive segments, thus keeping your computer on-guard status optimal.
Peak performance!
Shield Antivirus advanced detection engine & algorithms allow state of the art protection at a fraction of the load on your CPU!
24/7 Protection
Shield Antivirus settings are set to stand guard at all times. Simply install, set and forget. YOU ARE PROTECTED!
Shield Antivirus Features:
All-in-one PC security
Shield Antivirus detects and removes viruses, spyware, rootkits, bots, trojans and all other types of internet security issues. Shield Antivirus is an all-in-one computer protection software that keeps your computer safe, your privacy protected, and maintains the integrity of your information-security at all times.
Real-time active monitoring and protection!
Shield Antivirus utilizes multiple detection methods and advanced algorithms to monitor and protect against online and local security issues, including all known viruses and hacking types, in real time.
Ransomware PROTECTION!
Shield Antivirus detects and removes any known ransomware before it can take action and harm your PC.
Internet Security
Shield Antivirus protects you from malicious online websites and attempts to attack your computer and infect it with malware while you browse the internet.
Deep Threat Scanning
With one of the most extensive threat databases available to date, Shield Antivirus scan finds and eliminates many threats that other products in the industry fail to detect. Shield Antivirus’ databases and virus definitions keep updating on a daily basis from various sources, thus keeping your computer on-guard status optimal.
Scheduled Scans
Shield Antivirus’ scheduler allows a set-and-forget setting that lets you automatically scan and proactively protect your computer at all times. The combination of Shield Antivirus’ active protection and the scan scheduling mechanism provide a maximum security state, 24/7.
Automatic Updates
When needed, the virus, spyware and malware database will automatically be updated for free! This means that you never have to worry if it is up to date.
Secure File Eraser
Shield Antivirus adds an “Erase Files with Shield AV” option to your Window’s Explorer menu to permanently delete all traces of a file and make sure it is truly, completely deleted off your system and does not leave any unneeded residues behind.
To see this hidden content, you must reply or react with one of the following reactions : Like Like, Love Love, Wow Wow
