- 5,578
- 4,929
- 3,396
WinISO v7.0.3.8308 + Fix {CracksHash}
WinISO a fast and convenient ISO image file editorWinISO was originally designed back in 2000, and now it has been upgraded to be compatible with Windows 11, although the era of optical discs has faded away.
Features :-
High Efficiency
When updating a file in a large disc image file, WinISO overwrites only the updated parts, while leaving other data untouched. Without rebuilding the entire image, the file saving is fast.
Multiple Built-in Features
• Convert between disc image formats including ISO, CUE/BIN, NRG, MDF/MDS, CCD and IMG.
• Mount on the fly. Edited images can be mounted directly without saving in advance.
• Burn edited images without saving the changes, which is convenient for one-time tasks.
Instructions and Fix is provided in files
Virus Total links -
Setup - https://www.virustotal.com/gui/file/19730994419a21286590d43e02ea9e3a4626240ca8efa03baa3a701649375db7
Crack - https://www.virustotal.com/gui/file/35cb0d4908230dea919e8eebd041cc465c2d04d460322b156b199701a25d877a
Hybrid -
Setup - https://www.hybrid-analysis.com/sam...0d43e02ea9e3a4626240ca8efa03baa3a701649375db7
Crack - https://www.hybrid-analysis.com/sam...e8eebd041cc465c2d04d460322b156b199701a25d877a
To see this hidden content, you must reply or react with one of the following reactions : Like, Love, Wow
1. Install the program from the given setup.
2. Don't run the application yet and close from system tray or task manager if running.
3. Extract the "Crack Fix.zip" to directory where you've installed the program. Replace all the files.
4. Boom! Now you can use the program without any interruptions.
5. That's it, Enjoy now
