[PC APP] Acronis True Image 2018Build 10640 (22.5.1.10640) + Bootable ISO
Acronis True Image 2018 is a full-system image backup solution for your PC, Mac, mobile devices, and social network accounts. It can back up your documents, photos, email, and selected partitions, and even the entire disk drive, including operating system, applications, settings, and all of your data. Acronis True Image 2018 is an integrated backup and recovery software that ensures the security of all of the information on your PC.
Build10640Dec 22, 2017
Acronis True Image for Windows
Fixed issues
  • Unable to select a backup destination, the "Select destination" text is not clickable.
  • After the update from build 9850 to build 10410, the entries on the Activity tab are not shown if the number of the entries was quite large.
  • If the product was activated offline with a perpetual license, it demands reactivation when an Internet connection is enabled.
  • Under a WinPE media, the data cannot be recovered from a backup located on an NAS, the error "Acronis True Image backup file is corrupted" appears.
  • Backup stops after clicking "Back up now" if the setting "Do not back up on battery" is turned on and the power cord is unplugged.
  • In the notification area, the Acronis Active Protection icon is shown as unavailable after the update from build 9207 to build 9660.
Known issues
  • [TI-119448] The message 'The data you are trying to use is blocked at the moment. Please try again later.' appears on backup deletion.
  • [TI-115928] The archiving operation fails with error 'Write error' after the computer is woken up from the sleep mode.
  • [TI-54006] Some files remain on the local PC after archiving if the Internet connection is lost for some time during the archiving operation.
  • [TI-102104] Intel Stream x360 does not boot after recovery from a cloud backup.
  • [TI-100468] Acronis True Image requests credentials for a mapped public network share during the backup destination selection.
  • [TI-111221] The 'Do not back up on battery' option is not shown in settings after installing a UPS.
System requirements
Hardware requirements:
  • A CPU that supports SSE instructions
Operating systems:
  • Windows 10 Fall Creators Update (all editions)
  • Windows 10 Creators Update (all editions)
  • Windows 10 (all editions)
  • Windows 8.1 (all editions)
  • Windows 8 (all editions)
  • Windows 7 SP1 (all editions)
  • Windows Home Server
  • Windows XP SP3 (32-bit)
It is possible for the software to work on other Windows operating systems, but it is not guaranteed.
File systems:
  • FAT16/32
  • NTFS
  • Ext2/Ext3/Ext4
  • ReiserFS
  • Linux SWAP
Storage media:
  • Internal hard disk drives
  • External hard disk drives with any of the following interfaces: USB (including USB 3.0), eSATA, FireWire (IEEE-1394), and SCSI
  • Solid State Drives (SSD)
  • Networked storage devices
To see this hidden content, you must react with one of the following reactions : Like Like
PritongTinola
