COLORFUL Launches iGame X870E ULTRA-S V14 Motherboard
cybermediapr
Gems
COLORFUL Launches iGame X870E ULTRA-S V14 Motherboard​
1.jpg​
Colorful Technology Company Limited, a leading brand in gaming PC components, gaming laptops, and HiFi audio products, today announced the iGame X870E ULTRA-S V14, the latest addition to its iGame Ultra family. Featuring a striking black design inspired by the Ultra series, the AMD X870E motherboard combines enthusiast-grade power delivery, advanced memory overclocking, high-speed storage, and distinctive styling for gamers and creators.
The iGame X870E ULTRA-S V14 supports up to four 48GB memory modules at up to 6600MHz with CL28 timings, delivering high capacity alongside high-frequency, low-latency performance. It also features a 16+2+1-phase 80A DrMOS power design, five M.2 slots with three PCIe 5.0 x4 interfaces, and dual USB4 40Gbps ports for demanding gaming and creative workloads.
Distinctive iGame Ultra Design
The motherboard continues the youthful, hip-hop-inspired visual language of the iGame Ultra family. Its extensive heatsink armor is accented by distinctive graffiti-style typography and dot-matrix artwork, creating an instantly recognizable visual identity. Adding to its user-friendly design, the heatsink features M.2 quick-release latch for easy, tool-free access to the M.2 SSDs beneath, making upgrades and maintenance more convenient. Beneath the VRM nameplate, pixel-inspired ARGB lighting adds another layer of personality, with gradient illumination complementing the textures of the surrounding heatsink armor. The result is a motherboard designed for gamers who want their systems to stand apart from conventional gaming PC aesthetics.
Robust Power Delivery for AMD Ryzen 9 9950X3D
A 16+2+1-phase power design with 80A DrMOS provides the iGame X870E ULTRA-S V14 with a robust power foundation for high-end AMD processors, including the dual-CCD flagship AMD Ryzen 9 9950X3D. An integrated clock generator also enables CPU base-clock adjustment, giving enthusiasts more granular control over system tuning beyond conventional multiplier-based overclocking.
Extensive PCIe 5.0 Storage and USB4 Connectivity
For users building high-performance gaming and workstation systems, the motherboard provides five M.2 slots, three of which support PCIe 5.0 x4 connectivity. This gives users substantial flexibility for high-speed storage configurations and next-generation SSDs. The rear I/O also includes two USB4 40Gbps full-featured ports, providing high-bandwidth connectivity for modern peripherals and external storage devices. Together, these features make the motherboard well suited for high-frame-rate gaming as well as demanding creative workloads such as video editing and 3D content creation.
X3D AI High Frame Mode for Ryzen 9000 X3D Processors
Developed through COLORFUL’s Shenzhen and Taipei R&D centers, X3D AI Turbo Mode automatically optimizes PBO, temperature and power limits, and voltage settings for AMD Ryzen 9000 X3D processors. It boosts gaming performance and helps reduce FPS drops while maintaining multi-core productivity performance, giving users a balanced solution for both gaming and everyday workloads.
CPUAMD AM5 socket, supports AMD Ryzen 7000/ 8000/ 9000 series processors
ChipsetAMD X870E
Power supply phase16+2+1 Power Phase (Dr MOS 80A)
Memory4x DDR5 DIMM Socket Dual-Channel*, Support XMP/ EXPO
*Single memory supports up to 64GB capacity, total memory capacity supports up to 256GB
Support DDR5-8400(OC)/8200(OC)/8000(OC)/7800(OC)/7600(OC)/7400(OC)/7200(OC)/7000(OC)/6800(OC)/6600(OC)/6400(OC)/6200(OC)/6000(OC)/5800(OC)/5600(OC)/5400(OC)/5200(OC)/5000(OC)/4800MHz
Expansion Slot1x PCIe 5.0 x16, 1*PCIe 4.0 x4
Storage4x SATA 6Gb/s
3x PCIe 5.0 x4 M.2 SSD
2x PCIe 4.0 x4 M.2 SSD
Internal Connectors1x 24-pin ATX Power connector
2x 8-pin CPU Power connector
1x Front USB-C 3.2 Gen 2x2 Type-C
2x Front USB 3.2 Gen 1 Type-A (One pin)
4x Front USB 2.0 (two pins)
I/O Ports2x USB 4 Type-C (Support 4K Display output)
4x USB 3.2 Gen 1 Type-A;
3x USB 3.2 Gen 2 Type-A;
2x USB 2.0;
1x HDMI port;
1x DP port;
LANRTL8126-VB-CG 5G + Wi-Fi 7, Support Bluetooth 5.4
Audio7.1-Channel High-Definition audio CODEC
Dimensions305mm*245mm, ATX
Pricing and Availability
The COLORFUL iGame X870E ULTRA-S V14 motherboard will be available at a suggested retail price of CNY 1,899 (approximately USD 265). Pricing and availability may vary by region. For local pricing, availability, and purchase information, please contact your local COLORFUL Technology representative.
wazir2075
