- May 15, 2023
- 447
- 843
- 617
Data safety is a complex problem that requires you take care of many things. Paragon Hard Disk<br>Manager (HDM) consolidates 25 years of hands-on expertise in system software to keep your data<br>healthy and safe.<br><br>Data safety made simple for novice users and experts alike:<br>- Organize your disks, ensure capacity and performance of storage media<br>- Transfer systems on the fly, use physical and virtual appliances at will<br>- Use professional-grade backup to secure systems, applications and data<br>- Always stay up and running with boot fix and fail-safe system recovery<br><br>What's New in Paragon Hard Disk Manager 16:<br><br>Novice users:<br>“Complex” doesn’t necessarily have to mean “difficult.” Friendly wizards walk you through<br>all the steps necessary to successfully complete the most common tasks, such as setting up a new<br>computer, replacing an old mechanical disk with new fast SSD, recovering your system in case of<br>failure or malware activity, and more.<br><br>Expert users:<br>Expert users can leverage more sophisticated scenarios and invoke specialized tools providing<br>full control over specific tasks.<br><br>Protected mode:<br>We recommend using protected mode, which is enabled by default. In this mode, everything<br>you want to do is first placed in a queue, with changes applied only after user verification.<br>You don’t have to wait for an operation to finish before you can move on, since some operations<br>can take time to complete. More importantly, you can go back one step at a time in case of problems,<br>or to undo any changes already made.<br><br>Paragon Recovery Media Builder:<br>Hard Disk Manager also comes with full-fledged Paragon Recovery Media Builder to help correct<br>most boot problems that might occur from logical errors, hardware malfunctions, or failures.<br>Additionally, if your system becomes corrupted or compromised — including problems caused<br>by malware or ransomware — you’ll be able to quickly restore full operability of your system and<br>applications with minimal data loss.<br><br>Resize partitions on the fly:<br>Internal drive running low on available disk space? This dilemma often occurs when you have<br>multiple partitions to accommodate different systems and data types. With Hard Disk Manager,<br>you can resize partitions on the fly to maximize available storage capacity.<br><br>Clean up media:<br>When disposing of an old computer, it’s a good idea to first wipe personal data. Hard Disk Manager<br>makes this task a snap by irreversibly destroying data stored on a device. Alternatively, you can<br>opt only to clean unused space (in which case deleted files can still be restored), while keeping<br>useful data intact. You may be surprised to learn how much data leakage occurs from the<br>negligence of this simple rule.<br><br>Live transfer your systems and data:<br>Suppose you want to change your old mechanical hard disk drive (HDD) to a fast new solid-state<br>storage device (SSD). With Hard Disk Manager, you simply choose where you want Windows to be,<br>and there it is, ready to run. You can even continue working on your system while Windows is being relocated! No manual operations or reboots necessary — just switch over when ready.
To see this hidden content, you must react with one of the following reactions :
Love,
Wow
